thescreensavers
Got a question
From what I understand bigger rotors = better braking performance. Forget they can displace more heat or have more surface area.
But lets say you take a Car that's 2 tons with braking system, 2 Piston setup that can easily lock up the wheels and get ABS to go on.
Then you take the same car same tires and everything except you add bigger rotors, bigger pads to accompany the rotors and the same 2 piston setup, would there be a difference in stopping distance? Based on just 1 full stop(no fade..ect)
From 70-0? Highway speeds..ect
