I am currently using a supercase mid tower... the metal is kind of cheap inside the case. and its very noisy!
I have a full tower inwin case I could use(its ugly though). Would there be less noise coming from a larger case? I would be using same powersupply and everything.
Larger cases are usually sturdier and vibrate less, so probably the noise would be redused using that one. You can also sound isolate the small case. I have used corrugated cardboard from a box that was lying around.
Or you could pad the inside of your case with cheap carpeting. Ive heard that recommended over car insulation, as it's cheaper and equally effective. That could also save you from switching cases.
