Big, WIERD, win2k problem
Rifter
ok, this is kinda funny really but rather annoying. I cant access the properties or sharing screen on any of my drives or folders(you know, right click---->properties) when i try to go to properties it just does nothing, doesnt try to load, nothing. Now i want to set up some shares and i cant 🙁 how do i fix this?
ok, never thought of that, will try, but would like to know why it doesnt work anyways even if that works, i just cant go to properties for drives or folder, I can go to properties of files, just not drivers or folders.
All that context menu stuff comes from deep in the bowels of the registry. If it stops working, usually it means something down there is screwed up.
However, as a mere mortal, I don't delve there very often.
