Big watercool/pc problem...
Futher
1,362
I just installed my dangerden watercooling system.... I am cooling the cpu and my video card (Radeon 8500). I have a KR7A Raid motherboard. I turn it on, and everything seems to be working, but I am not getting a picture on the monitor... I tried plugging it into my TV, no luck there either. I plugged in my PC speakers to hear the beeps, but that didn't work either... didn't make a sound. PLEASE help, thankyou
mee987
773
This probably has nothing to do with the watercooling... i suggest you post this under "technical support"
BeauJangles
13,941
your computer is not completing it's POST procedure, which means something is wrong. If you have a speaker plugged into the motherboard you should be able to hear a series of beeps and, by looking them up in your manual, you can figure out what's wrong. If your system was working fine before you installed your watercooling I would guess one of two things. First, your mobo requires a fan to be plugged into the 'cpu fan' header on the motherboard or it will not POST, or second, that you did not attach the waterblock properly and fried your CPU.
SnowPunk98
Banned
Jun 15, 2001
4,933
You have all the power plugged in? check that. Also did you use a shim when you installed the CPU block? may have cracked the core if not
