- Jul 16, 2003
- 424
- 13
- 81
Hi I just built a new system. It's in my sig under gaming rig. Anyway I'm getting an idle temp of 38C and about a 44-45C load temp and this is all stock settings. Thermal paste I used was AS5. The DFI Ultra-D comes with a plastic backplate so I had to use the thermaltake one (alternative K8 install method on instruction sheet). I tried to tighten the tiny nuts on top of the H plate as much as I could using my hands. It seems like it's on there really good but perhaps not enough according to my temps? I tried going to home depot to find a small wrench I could tighten them up more with but they don't carry one that small.
What do you suggest I do? I know a lot of you use the same mb as me so how did you tighten those little nuts on the screw? Are there any online stores where I can get a little wrench to fit it so I can tighten it up more? Argh frustrating!
Thanks in advance for any feedback
