Big problem, used Driver Cleaner Pro...
WangoZ
419
I used Driver Cleaner Pro last night to wipe out some NVidia drivers for installtion of new ones. I removed chipset, display and cab files. I had disconnected my internet connection as well. When I tried to reboot I got an error message saying I am missing this:
System32\drivers\nvcchflt.sys
I have a DFI NF3 250 gb Ultra board..
Can anyone give me some insight? I also tried to use my disc to "repair" but I have NO IDEA what to do once I get there..so many choices!
Parkre
616
Hey, i did that too, last week. with driver cleaner. I got the same error (or similiar). So I just reinstalled windows.
WangoZ
419
I am trying to NOT have to reinstall... I'll lost to much info. I tried to "repair" using the windows disk, it ran through the repair just fine, but didn't fix the issue...
What I did leanr is that that file also was about this:
NVIDIA disk cache filler driver
Anyone else have any ideas on how to get this file fixed so I can boot into windows?
bruceb
8,874
111
Try booting up in SAFE Mode
and then reinstalling the NVIDIA
Drivers ... Safe mode uses the
old default VGA Mode
WangoZ
419
Hi Bruce..
I tried safe mode, still gives me the same error...This is a tough one judging by the "silence" here :)
bruceb
8,874
111
I can only suggest a couple of ideas:
1): Reboot into Windows Safe Mode, then do a repair install to reinstall the
VGA motherboard chipset & display drivers ... if you don't have them or know
which one to get, use Everest Home Edition to ID the motherboard make & model,
then get the drivers from the motherboard web site
2): Does Driver Cleaner Pro have a Restore or Undo feature ? .. If so try it in safe mode
3): You may to post here on this forum for Driver Cleaner Pro
http://www.driverheaven.net/showthread.php?t=76416
Good luck
Megatomic
20,127
Wayne, this happened to me once also. I was unable to fix it so I had to reinstall windows, too. Luckily I had all my stuff archived properly so I didn't fret over losing data.
As a result of this process, I reverted to an older version of Driver Cleaner, it doesn't cause this problem for me. I think 3.3 is the one I'm sticking with for a long while.
WangoZ
419
Thanks for the advice Jeff and Bruce...I fear all is lost that I haven't already backed up...I'm going to do a fresh install...Sheeesh I feel stupid.
