Big Issues with AMD system
wolf2009
1,000
CPU - Athlon II X2 250
Motherboard - Gigabyte MA770T-UD3P
RAM - Crucial 4GB DDR3 1333
OS - Vista x64 SP2
This is my first AMD system, so need explanation of a few stuff in bios.
http://i25.tinypic.com/2d7sttt.jpg
1. That TMPIN2 temp is scaring me. What is that ? It stays there, it doesn't go up when the CPU is under OCCT stress test.
2. Cool & Quiet was working with F1 bios on this board with the CPU downclocking to 0.8 Ghz. Updated to F2 and it doesn't work anymore even though it is enabled in bios. C1E is also enabled.
3. I set the the voltage for memory as 1.5V in Bios, but AMD Overdrive 3.0.2 is showing me 1.8V and doesn't allow me to lower it than 1.8V
http://i26.tinypic.com/ekqr9h.jpg
while HWMonitor shows 1.62V
4. The frequencies are strange. IT should be 3000 Mhz for CPU, but it is 3020, for Memory it is 1333MHz in bios. It should be near 667Mhz, but it is 671
5. There are two voltages for RAM. One is DRAM Voltage and the other is DDR VTT voltage. What is this VTT voltage ?
http://i31.tinypic.com/aud36f.jpg
6. the ACC is disabled in Bios. It offers options such as auto, and +%(number) and -%(number) . What do these values do ?
http://i32.tinypic.com/2qkr0uw.jpg
7. What is better for this option
http://i32.tinypic.com/15eztxs.jpg
