BIG Culprit in High Energy Bills!!!!
Kaido
Feb 14, 2004
48,732
5,470
hans030390
7,326
To the OP, I had one of the nicer DVR boxes from Comcast. I believe it was a Motorola unit. It drew less than 50-60W, but I do not know the exact amount. I plugged my surge protector into a Kill-A-Watt, which powers my plasma TV, 3 consoles (360, PS3, Wii U), stereo receiver, subwoofer, and, of course, the DVR box. With all devices but the DVR box set to off or sleep (ex: subwoofer "sleeps" until it receives a sound signal), Kill-A-Watt reported 40W or less. Some of that came from the other devices in sleep mode, so I'm guessing the DVR box drew maybe 30W. I can't imagine it drawing more than 50-60W when playing HD material and recording at the same time. I could be wrong, but the DVR box was "idle" most of the time anyway.
I can't speak for other DVR boxes, but that's fairly low. I'm not sure I would put that anywhere in the top 3 power-consuming devices when I have 3 gaming rigs alone (1 is mine) that draw 100W+ on idle and are each on for maybe 8 hours a day or more. Oh, and the plasma TV. LOL. That beast can draw close to 300W at times depending on what it's displaying.
I use an mATX HTPC computer with a cable card tuner (Verizon FIOS). When not in use it is in sleep mode and consumes >5W. The other TVs use extenders that use very little electricity when powered off. A quick calculation would indicate that I save @ $10 - $12 a month in electric vs. using cable boxes.
There are some drawbacks in the I don't get on-demand or PPV programming. On the flipside my box has 4 tuners and I could upgrade to a 6-tuner version if I wished. I can also do Netflix, Hulu, You Tube, Vudu, etc; stream DVDs, Blu-rays and music from a local server; and bring up a browser and stream from whatever is available on the internet. The HTPC has a BD player too with TotalMedia Theater so I can also slap a Blu-ray disc in if I like. As a final bonus the cablecard rental is $2.99 a month. If I had 3 HD cable boxes with DVR capabilities that would cost @ another $45/mo.
I have also replaced my DVR box with an HTPC using a Ceton PCI-E cable card tuner. It draws more power than the DVR box, but it is around 30-40W idle and spends most of the day in sleep mode (very low power consumption). I'm not sure how much it draws while recording and watching TV, but it shouldn't be too bad. Even if it were running at full load 24 hours a day, I calculated out the power consumption vs. the $18/mo I was paying to rent a DVR box, and I'd still save around $10 a month with the HTPC. The HTPC will easily pay for itself in a couple years, not to mention the added value it provides over a DVR box (it can do ALL the things).
Plugers
547
Unfortunately, they are all newer models. Probably not what you have in your home.
ComputerWizKid
1,187
Yeah the cable company (Charter) refuses to give out the new boxes
I have a POS Scientific Atalanta (Now Cisco) Explorer 4250HDC
Anyone remember the OLD CFT2200 boxes
Test-Chip Lol!:thumbsup:
glugglug
5,340
Yes, the TWC DVR boxes use 90W when "off".
Taking into account that Con Ed bills you for about triple what you actually use, that means you effectively pay around $1/kWh. Which works out to $65 per month to CON Ed for the DVR, plus TWC raping you with separate charges for DVR "Service" vs. DVR "Rental" and "Guide Data" and "Service Duplication", bringing the total to just about $100 per month per DVR.
Part of the reason they use old energy hogging hardware is to avoid having to deal with their own abysmal cable-card support. By using boxes from before 2005, they are grandfathered in from having to use the cards.
GotNoRice
329
Here in California, under PG&E we often have the majority of our usage billed as high as $.50/kWh. 4-digit power bills are not unheard of. Then again we're not exactly the most efficient users.
Why do so many computer assemblers insist a computer needs a 600 watt supply or larger?
Some of us can actually put our big power-supplies to use.
That was when I was running 2x 4870x2 in Quad Crossfire, which I retired in 2012. My usage has gone down since then but I certainly never regretted buying a 1000w PSU.
CurrentlyPissed
660
10
How are you even employed with that level of English.
To contribute to the thread, I thought this was old news. More so for DVRs.
Kaido
Feb 14, 2004
48,732
5,470
That's why I'm so impressed with Intel's NUC platform. 30w max, and only 5 or 6 watts at idle - even while the OS is running!
Mr. Pedantic
5,027
OP reminds me of Kevin Trudeau.
Common sense power consumption tips that THEY DON'T WANT YOU TO KNOW!!!!
