BIG BIG PROBLEM!!!
rh535
95
I was in windows xp and i deleted dome files. And i have a dual boot with fedora core 3 and windows xp with windows being windows the default os to startup. When i boot up my computer is says this
Booting 'Windows XP'
rootnoveify (hd,0)
Chainloader +1
NTLDR is missing
Press Ctrl+Alt+Del to restart
What should i do?
MrChad
13,507
"Deleted some files"? What does that mean exactly?
Your best bet is to run a repair install of XP to replace whatever critical files were deleted.
screw3d
6,906
Boot into console using your Win XP CD, try doing fixmbr?
This will probably override Fedora's bootloader.
Seeruk
986
Originally posted by: Izusaga
First problem would be Windows XP.
Wrong!!
Anyway ... I am assuming you used something like Grub/Lilo as your boot manager? In which case one of the files you may have deleted is the loader, or it could be the conf file that configures it.
XP needs to be the active partition to boot and this is made possible by the conf file.
Fix MBR may get your XP back, but not your loader to get into FC. Better to perhaps boot with a Linux Live CD and fix the loader.
Which were you using as your boot manager?? XP or Grub/LILO/whatever
rh535
95
After i put in the xp i get the blue screen and i select repair and a black screen comes and says
Microsoft Windows XP-Recovery Console
1: C:/WINDOWS
Which windows installion would you like to log out
I can only type i letter in the area.
What should i do?
rh535
95
I think it is GRUB
It asked for my admin password but i forgot it.
What should i do to get my password?
Seeruk
986
Nope its not GRUB - sounds exactly like the XP recovery should be.
If you have never set an admin password it will be blank so just hit enter again. If you have set one at some point and forgotten it then its going to be a whole lot more complicated :)
filterxg
330
Just to give you a heads up the recovery console will likely restore the MBR to whatever msft thinks it should be. If the primary boot loader is a linux (lilo/grub) or 3rd party (xosl) you are going to have some problems.
rh535
95
i got to restore MBR but it still says this
NTLDR is missing
What should i do?
birdpup
Banned
May 7, 2005
746
Put in the WinXP install CD, reboot the computer, select the repair install. This will replace the core operating system files that are needed to get back into WinXP.
rootnoveify (hd,0)
Chainloader +1
The rootnoverify (hd,0) and Chainloader +1 lines are from GRUB.
Since WinXP will fixmbr, it will be necessary to use the FC install cd later to regain access to FC. You then have your choice of boot utilities. You can maintain WinXP's boot utility by copying the needed file from FC into WinXP and then putting an extra line into WinXP's system startup routine OR you can reinstall Grub. The choice is yours.
rh535
95
I don't really want to keep Fedora Core 3. But When i click repair(r) what do i select in the command line?
timswim78
4,330
No, his message says that he deleted "dome files." Everyone knows that you should never delete dome files, unless you want to mess up your bootloader.
In all seriousness, I agree that he should repair install XP and then reinstall linux on top of itself. Everything should then be OK, and all of his files should be intact. However, he should definitely back up the drive before doing the reinstalls.
rh535
95
I get to the black screen after i select repair ( r ) the command propmt and what do i type in there for repair?
Seeruk
986
fixmbr
rh535
95
I typed fixmbr and it says it worked but know it says
NTLDR is missing
What should i do?
SleepWalkerX
2,649
go to your BIOS and look at the first page. it should list your devices. primary master device, primary slave device, secondary master device, and secondary slave device. now pick whichever one is your hard drive you're booting in to. change the access mode to "LBA". i had this very same issue and this fixed it, now grub/lilo can boot in to windows without that message. although yesterday i updated my bios and i didn't have to set it to LBA.
MrChad
13,507
NTLDR is missing
What should i do?
Did you run a repair install or just go to the recovery console?
timswim78
4,330
To do a repair install of XP, DO NOT USE THE RECOVERY CONSOLE. Follow these directions, or google for something like "repair installation Windows XP"
XP Repair install
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
To setup Windows XP now and Repair Install , press ENTER. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, read this Warning#2!
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
If you get files not found during the copying stage.
Blaster worm warning: Do not immediately activate over the internet when asked, enable the XP firewall before connecting to the internet. You can activate after the firewall is enabled. Control Panel - Network Connections. Right click the connection you use, Properties, and there is a check box on the Advanced page.
KB 833330 Blaster removal
What You Should Know About the Sasser Worm and Its Variants
Microsoft Security Bulletin MS04-011
7. Reapply updates or service packs applied since initial Windows XP installation. Please note that a Repair Install from the Original install XP CD will remove SP1/SP2 and service packs will need to be reapplied.
rh535
95
When ever i put my xp cd the blue screen comes and says ENTER and repair( r ) i select ( r ) and it goes start to the black screen what should i do from there to do a repair?
rh535
95
Originally posted by: birdpup
Michael Stevens How to Perform a Windows XP Repair Iinstanstall
Okay i went with warning #2 is that right? Also i type in bootcfg
and i get
/SCAN-Scan all disks for windows installions and display results
/ADD-Add a windows installion to the boot list
/REBUILD- Iterate throuogh all windows installtion the and allow the user to choose which to add
/DEFAULT-Set the default boot entry
/LIST-List the entries already in the boot list
/DISABLEREDIRECT-Disable redirection in the boot loader
/REDIRECT-Enable redirection in the boot loader with the specified configuraton
What should i select?
