- Jan 18, 2001
- 14,465
- 1
- 0
I am about to take the bike in and get it fixed, but i have some expereince and tools working on bikes. However, I don't really know where to start with this problem
Problem Description:
When I stand up to accelerate hard, or hit a hill and apply moderate amounts of torque to the petals the derailure in the back appears to move on me, causing the gears to momentarily shift down into lower gears.
This is really frustrating and disconcerting at times. Is my shifter cable too lose? Is there something on the derailure that might allow me to adjust the sensitivity?
http://pics.bbzzdd.com/users/homebrewerdude/LeMond.jpg
the bike is relatively new, and has shimano tiagra rear derailers.
UPDATE:
I decide to let the shop look at it when they told me they wouldn't charge me for a quick check up.
As some people guessed, the derailleur cable had lost a bit of tension. This resulted in the derailleur pulleys being slightly out of aligned with the free cog. More specifically, the derailleur was shifted to the outside by about 2-3 mm. My bike had a quick adjust tension nut on the cable, so the solution was to give that nut a few turns. The mechanic did not need to mess with the set screws.
Bike is riding great now. thanks again
UPDATE:
