is there still ink? you just gotta roll that ball around until the new ink gets on it. thumbs work well for that. something with grip, so that the ball doesn't just slide across without rotating.
Just throw them away. Bic standard ball point pens are the biggest pieces of crap ever, I think they're Ford's standard issue If you want cheap pens that work, get standard papermate ball point pens. They don't leak like bic pens occasionally do and they last until all the ink is gone. Otherwise, uniball pens have always been good for me...
<< is there still ink? you just gotta roll that ball around until the new ink gets on it. thumbs work well for that. something with grip, so that the ball doesn't just slide across without rotating. >>
well , all of them are brand new.............just that I haven't used them for ages
