Bi-metal hole saw's for case mod's--warm
keyman923
Production tool supply has a sale on Black&Decker Bi-metal hole saw's with shank. I bought them at one of there retail stores and they have a website www.pts-tools.com but they don't have them listed on the site, there phone# is 800-366-3600. The price on the 4 3/8" (112mm) is $13.90---4 1/2" is $16.40---3 3/8" (86mm) is $5.45, plus .70 for a 1/4" pilot drill for the hole saw. my local tool store wanted $37 for 4 3/8 and $25 for the 3 3/8.
I bought the 3 3/8 and the 4 3/8 to install 92 and 120mm fans. I auctually like to cut the hole a little smaller than what the fan size is cause it always turns out to be a little bigger.
I also see now they have a 12 piece black & decker set for $48.50 reg. $149.50 with the following hole saw's---4 1/2---4 3/8---4 1/4---4---3 7/8---3 3/4---3 5/8---3 3/8---3 1/8---2 3/4---2 5/8.
The part #for the 12 piece is is FZ51-SET2
These all come with a 3/8" shanks so they will fit in most drill's--some other brands of hole saw's come with a 1/2" shank and you need a 1/2" drill for those.
The website says free shipping.
These look like the ones on the right-you install the pilot drill bit (1/4") and tighten the set screw and your off drilling nice round holes to install your new case fan's.
The nice thing about these that once you go above 4 inch in a hole saw they get expensive and for the cost of 1----4 1/2" anywhere else your also getting sizes to do 80 and 92mm fans.
These are bi-metal not those cheap hole saw's made for wood.
link
It's $100 off, so it really more of a hot deal than warm.
You probally can I'm just not sure how since I use there retail store-they have a toll free #call them during the day, It looks like there set up for email order's
