~~~BH7 and MBM5 settings And BIOS temps??~~~
EXman
20,079
15
Hey you all with BH7's you all suggested the BH7 so I got it!
I am having a problem finding out just how hot the CPU is as the BIOS says 48-51 C I do Overclock my 2.4B to 3ghz (18x167) I think this is High and I reapplied the AS2 and reseated my Zalman 5700. Still have High temps :( So I tried to install the Motherboard Monitor 5 and all the different settings are not working for me I keep getting the MBM5 to read 127 degrees Cel not Far...
which sensors settings do you use for Temps in MBM5.
My Chip seems to keep booting as High as I dare try it but the temps are way to high. It seems these temps are more indictative to an old T-bird not a P4....
my Zalman fan is just plugged into the mobo w/o the speedfan thing-a-majig.
Tates
9,079
10
I have MBM5 temps set to:
1) Windbond 2 Diode (CPU)
2) Windbond 1 (System or MB)
3) Windbond 3 (4 phase PWB)
Abit MB's read temps on the high side.
LastRide
946
The BH7 reads really high temps.I wanted to get one but I am passing on it.Its a good board other than the crazy temp readings.
EXman
20,079
15
The funny thing is that it moves so fast up and down (4 degrees) even when idle... that bugs me :(
Board was pretty easy to set up though.
EXman
20,079
15
Using the #'s that Tates gave me I am getting 42 degrees C for CPU 28 for system and 34-35 for the power supply. These are more in line with what was expected yet still a bit high. and this is at a lower speed 2889Mhz @ 1.55V was getting wary of the temps
seem ok to you all? btw thanks Tates!
