BH-6 voltage settings
virtuamike
7,845
13
Trying to overclock a Celeron II 566 -> 850 but the only volatges I get to choose from are 1.30V-1.70V in 0.05V increments. Using an MSI 6905 and v1.0 BH6, using latest BIOS version. Any ideas? Is this a slotket or motherboard issue?
WinXP
1,021
The Bh6 will not let the slocket overide the bios for setting higher voltages.To get higher voltages reflash the bios ss with the /cc command and you should see higher voltages in bios(1.95). Before relashing set bios core voltage to 1.7v then reflash awdflash ss.bin(space)/cc an you should have the higher voltages in bios. This works for the bh6 an bx6_r2. If you want higher than 1.95v if you have the ss bios flashed now an want higher than 1.95v set it to 1.7 volts first reflash with previous bios an /cc command then reflash again with ss bios an it should voltages in bios to either 2.05 or 2.1volts.
