BG7 and front audio question
kgraeme
3,536
For those with the BG7 mobo and using it with a case with front audio connectors: if you connect the front audio cable to the header does it disable the rear audio ports, or does it leave them active until you plug headphones or some such into the front jack?
According to the Intel spec it should be the latter, but reading the manual it appears that plugging into the header (and switching the appropriate jumpers) disables the rear audio ports entirely.
kgraeme
3,536
Alright you scurvy dogs! I'll give you one more chance before I come over there and gnaw your legs off. Answer the question and then you can go get fat on your holiday bird. No answer, no legs. Turkey or otherwise. :disgust: :D
