BFG Nvidia 6600 gt oc not recieving enough power
bprogar
Ok, i know this problem has come up many times, but it seems that there is no solution to mine in particular. I recently built a new comp with pcie. The BFG tech Nvidia card i have is a pcie 6600 gtoc, and no there is no molex connector on the card itself, it is powered through the pcie slot. I have a 400w psu atx12v 2.03, with a 24 pin main power connecter, including the 2x2 mobo power connector as well. Both of these connectors are connected to my motherboard. I am recieving the same problem as many others, but it seems that it is only for one game. I havnt had the time to run a test on other games of yet, to see if it is a problem with something i recently did, but at any rate, i just started getting this problem (so far it only happens while playing the game "Guild Wars").
comp specs.
Bios v6.00
Motherboard - Foxconn 915ao3-p-8ekrs
processor - Prescott p4 3gig w/HT
windows xp.
ive tried old video drivers such as the nvidia drivers 66.93, and ive tried the newest drivers, cant remmber the number. Im even about to try the 73.00 you can download from guru3d.com. But im going to wait untill after finals for this in case i mess up my comp. I have updated the chipset drivers on my mobo.
Im about to reinstall windows, i have no idea what is going on or why. It does not make sense.
Any help would be greatly appreciated. (im begginning to think its a bad card, but well see)
Brendt Progar
How do you check out the ampage on the 12v power line? As far as hard drives and optical drives go:
sata hard drive
hard dirve
floppy
dvd rom
3 ram sticks equaling 1.5g ram
network card
sound card: audigy
and obviously the video card.
What kind of power supply would you recommend? Antec? And if so what model number? I have no idea how to check out the amperage on any of the power lines.
On the retail boxes of power supplies, as well as on the PSU itself, there will be a table of the max amperage at each voltage.
