BFG GF 7800 GS fan whine
Lupinicus
27
About a month ago, my computer case would randomly start emitting an extremely high pitched whine. It's almost the most annoying sound I've ever heard. Actually, it was not completely random, it seemed to happen during high loads especially during games. Well, a good thump on the case was a temporary solution and at that point it was not happening constantly. Unfortunately, the problem continued and I eventually opened up my case and realized the whine was from my video card. I have a BFG GeForce 7800GS OC and I am almost certain the whine is coming from the card's fan. At first, I just used some canned air to blow all the dust out of it (I've had the card for about 9 months now, since it was released earlier this year). That solved the problem for a day or 2, but the whine came back. At that point, I removed the card, unscrewed the cover on the fan/heat channel thing, and squirted a little WD-40 on to it. I realize that might not have been the best idea, but I was desperate. Again, this solved the problem for a couple days, but now it is back and worse than ever.
It will make the whine at almost any time now. When it's not during a game, a tap on the case will make it go away for a while, but it will always come back. If I'm playing a game it will be much more frequent. Has anyone had experience with this kind of problem before? What should I do? I don't want to get a new video card, but I guess I will if I have to.
happy medium
14,387
480
I have the same card and mine does the same thing at startup and then goes away.
I used a fan speed control in rivatuner and it only runs at high speed during gaming. I don't here it then anyway. I have the fan set at 60% when not gaming.
Bill Kunert
I've got a 7600GT which had a fairly noisey fan. I stuck a Zalman VF900 Copper on it and even on high speed you cannot hear it. Dropped my temp to the point where the card stays below 62 degrees under load and my card is overclocke 200MHz on processor and memory. They were on sale for $33 at New Egg.
