BFG 7900GTX power problem
Bearcat14
53
I have a BFG 7900GTX which was working just fine until recently when my PSU died. I replaced the PSU with an identical model (Ultra Infinity 600W), and now on startup I get a message that says that there is insufficient power reaching the video card, and to plug in the supplemental power. I think there is only one (6 pin) power connector for the card, and it is plugged in. A 600W power supply should be more than ample for this card, and it has always worked in the past. Anyone have any ideas on what I'm missing here?
FYI, I am using an ASUS A8N-SLI-SE Motherboard, with a single 7900GTX OC on it (no SLI). Graphics seems to work but the alert box says "Performance will be degraded". Any ideas?
Thanks in advance!
DaveSimmons
40,730
670
Does your PSU have a second 6pin you can try instead for the card?
Did you forget a secondary motherboard power plug?
