I originally posted this in another thread, but I see my problem differs a bit from the other one, so here comes a new thread.
Paste:
There are no problems with the card not fitting or damaged components. CPU/RAM is not clocked and I've tried to increase/decrease AGP voltage. When I press the power button, there is a constant high pitch beep which doesn't stop until power is shut off. The monitor acts like it receives no signal and remain black. It couldn't possibly be the PSU, since I have a 520W Aspire PSU with 37 Amps max on +12V.
Suggestions?
Edit: As you can see in my signature, I usually run the CPU overclocked to 2.4GHz, but clocked it down for the occasion.. (after having found out it didn't work the first time)
Paste:
Suggestions?
