BFG 6200LE 128MB PCI-E - $9.99 or less AR
dairen
14
Aloha All...
Longtime lunker finally able to contribute something this great forum!
Stumbled across this while looking for a cheap PCI-E card for my secondary PC.
3DFuzion 6200LE 128MB Graphic Card PCI-Express with $25.00 rebate at Frys.com and Buy.com
$34.99 (have to add to cart to see price) @ Frys + shipping
Net price AR = $9.99
Buy.com link
$38.49 @ Buy.com with Free Shipping
Net price AR = $13.49
If you can use Google Checkout - $3.49 shipped AR
Frys link
A few comments:
No VGA, only DVI & S-Video (edit: the product picture on Newegg shows a VGA port, so it may have both VGA & DVI)
Reviews indicate that the fan on this is may be noisy and of course the gaming performance is lacking. But if you're like me and planning to just use this for basic video, it should be fine.
For my fellow Hawaii buyers, add another item to this @ Frys and shipping will be the same or just slightly more than the $19.99 ouch! shipping for this alone. I ordered the Patriot 4gb RAM deal, but the 750 GB PATA Seagate is also a good choice (shipping increases to $21.99 for the combo). Buy.com shipping is outrageous to Hawaii (>$36.00 for the card alone!).
DefDC
1,858
Grabbed one. Nice deal. A few bucks cheaper for me at Buy.com. Thx OP!
Zap
22,377
7
Hello dairen, welcome to the forums and thanks for such a great first post!
Originally posted by: magreen
Any idea whether this is better than nvidia 6150 integrated video?
Yup.
txlonghorn
380
The spec says:
Graphics Resolution
2048 x 1536 @ 85Hz Analog 16.7 Million Colors (32-bit)
1600 x 1200 @ 60Hz Digital 16.7 Million Colors (32-bit)
2048 x 1536 @ 85Hz Maximum Analog
1600 x 1200 @ 60Hz Maximum Digital
Does this mean it can't drive wide-screen monitors (1680x1050) at its native resolution?
magreen
1,309
Yup.
Is it a whole $3.50 better?
j/k. But do you know how much better?
actually, I just heard that these things are a pain with turbocache that wastes your memory bandwidth and memory. Can you turn off the turbocache completely?
I'm also wondering about the 1680x1050 question since that's my monitor's only resolution it can display properly.
superHARD
7,828
You guys remember the guy that OC'ed the heck out of his 6200le? with a couple v-mods this core is amazing...and bulletproof :)
DefDC
1,858
Dumb question here... Where is the UPC? I pulled out the card, installed it, and looked on the box for the upc, but there was hole there.. (Professionally cut, not with scissors There was a note saying "Cashier: If no UPC is found..." And I can't find the UPC on any of the packaging...
Anyone else find it?
txlonghorn
380
Mine UPC was on the plastic wrap, located right where the hole is. However, the rebate form asks for "Proof of Purchase" printed on the box, not UPC. I plan to send in both.
jiffer
375
54
It's not a dumb question at all.
There are two things to look for. 1) There is a "Proof of Purchase" printed on the side of the box that you can use for the rebate. If I recall correctly, I think that's what I used the last time I bought one of these cards. (I received the rebate without any problems.) 2) The hole you're talking about is a window (pre-fabricated when the box was made) that is supposed to let you see the sticker on the card itself. The UPC code is printed on an adhesive label that is attached to the shrinkwrap over that window. If the shrinkwrap or the sticker has been damaged, the UPC code might be missing.
I hope this helps.
EDIT: txlonghorn beat me to it. It looks like we concur.
txlonghorn
380
Originally posted by: txlonghorn
The spec says:
Graphics Resolution
Got the card. Tested it out. No go for wide-screen 1680 x 1050. Oh well. I can't use it as the main card for daily use. But, it makes a handy utility card for testing.
DefDC
1,858
*Whew*. You're right. It says it needs the "Proof of Purchase" for the rebate. Reading comp FTW! ;)
Thanks guys!
magreen
1,309
The spec says:
Graphics Resolution
Thanks for the 1680x1050 update.
Looks like this isn't the card for me!
deadken
3,199
I was ready to 'pull-the-trigger' on this card, but the 64bit Memory bus makes me feel uncomfortable. I know it won't handle any 'real' games, but 64-bit just rubs me the wrong way.
I did some looking around and found what looks to be a 128bit 256MB GeCube X1050 card for $19.98 shipped (AMIR) from Newegg. I just asked in the Video Card section if it would in fact beat out this 6200LE. If I hear back that it will, I will start up another thread here in the Hot Deals section.
I truly don't think that I am thread crapping. I sincerely hope that I don't come across as hostile or something. Perhaps someone here will be able to tell me if this is worth the 'extra' $7 over the 6200LE.
Also, please realize that the X1050 uses the same RV370 core as the X300, X550, and X600 cards.
Zap
22,377
7
Last year I ran a similar card for around 3 months. At the time all I played online was WoW and WolfET, but it played those just fine. I had gone from an x800GTO (16 pipe unlock) to a 6200TC because I sold the card and hadn't found a replacement yet (eventually went with a passively cooled 7900GS) and was gaming... wondering "hey, why does it chug every now and then?" Oh yeah! Just had to reduce settings a bit and those (rather undemanding) games played just fine.
Crysis? Not. Other games? Maybe.
Odeen
4,892
The spec says:
Graphics Resolution
Last time I checked, you can create any resolution you want using standard nVidia drivers. I have 1680x1050 on my laptop but, for some bizzarre reason, didn't have 1280x800. Once I diagnosed the problem, I was able to set up 1280x800 in a few minutes.
Odeen
4,892
Well, the reason for 64-bit memory bus is that they can get away with half the memory/GPU connections, and they can build the card on a half-height PCB. 128-bit would mean they're using a bigger PCB, and the price would go up accordingly.
