Heis
Comparing between these two fans, which one would you suggest I buy as intakes for the front of my case? I will be buying 2 for front intake.
Noctua NF-A14 PWM: http://ca.pcpartpicker.com/part/noctua-case-fan-nfa14pwm
or
Phanteks PH-F140SP: http://ca.pcpartpicker.com/part/phanteks-case-fan-phf140spbk
Which of these two fans have more static pressure in order to move more air?
The case I will be using is the Phanteks Enthoo Luxe, Im going to be connecting these fans to the provided fan hub in the case. These Phanteks fans are actually the same fans that come with the case for the rear exhaust and top exhaust which I will leave them there and be using. I heard the Noctuas will be voltage controlled, Im not sure what this means, if somebody can clarify this.
Thanks in advance!
or
Thanks in advance!
