- Dec 15, 2004
- 4,504
- 2
- 0
Supposing you don't care about the time factor, say you have a timer that turns on the water heater an hour before you wake up, and turns it off an hour after you go to work, then brings it back on an hour before you get home, and then off about the time you go to sleep. So your heater would be on say 5-8a, then again 5-10p. So it would have its power cut for 16 hours a day.
Has anybody done the power calculations to see if this saves an appreciable amount on the electric bill? You would use a significant amount more power for a short time when the water heated up, and I suppose it all depends on the insulation factor of your water heater.
I know that we save about 30% over last year with a new programmable t-stat that lets me set the temp to 88 for a number of hours during the day, and to make it a couple degrees warmer at night.
