i get data corruption over 160fsb....its either the hdd or the controller....would a controller card (with a new hdd) get me around this? anyone with any exp on this??
i wouldn't trust a controller card, it's the same crap as the onboard-controllers.
even if you don't oc, your data is in permanent danger due to the simple logic these controllers use.
Nah. It doesn't matter weather you're using an On-Board or PCI card, they're both still devices on the overclocked PCI bus, won't really make a difference by using a PCI RAID or ATA/100 card.
I heard of people using the TX2 (I forget the manufacturer) for higher bus speeds because it was a 33/66MHz PCI card, and designed to handle 66MHz PCI bus. I dont remember it very well, though
<< I heard of people using the TX2 (I forget the manufacturer) for higher bus speeds because it was a 33/66MHz PCI card, and designed to handle 66MHz PCI bus. I dont remember it very well, though >>
