- Apr 27, 2001
- 1,246
- 107
- 106
I'm a bit of an audio newb. and would appreciate any advice to get me pointed in the right direction.
My current setup works fine for movies, but sounds muddy/not so clear when listening to stereo music (I can not really distinguish the individual instruments), and I would like to improve it if I can.
I have a 5.1 setup with Polk Audio Monitor 70's for Front Right and Left, Monitor 40's for Rear Right and Left, CS2 Center and PSW 505 Sub.
The front (Monitor 70) speakers each have 4 individual speakers and a tweeter, and each speaker has two separate pairs of inputs with a small copper bar that connects them both together. The top input on each speaker powers the two top speakers and the tweeter, and the bottom input powers the two bottom speakers. I believe I could remove the bar between the top and bottom inputs and install an (in-line powered 2-channel crossover)? to send higher frequencies to the top two speakers & tweeter while sending lower frequencies to the two bottom speakers. This would have to be done through the speaker wires as I only have speaker wire outputs from the AVR (no RCA jacks except for the subwolfer/LFE).
Whenever I search for crossovers, however, I only find links to car audio equipment, but nothing for home audio.
Am I barking up the wrong tree? Should I be looking for a better AVR or adding amplifiers?
AV Receiver is a Harman/Kardon AVR1700.
The AVR crossover frequency to the fronts and rears is set at 120 Hz.
The crossover to the center is set at 80 Hz.
These seem to be the best settings for music.
I mostly play music on my PC and connect to the AVR via an HDMI cable through the video card.
Any loss of music quality there?
Thanks.
Thanks.
