Price aside for a second. I've seen online reviews showing the 6990 will OC to around 1000 MHz on water, and I'm pretty sure you could get the same out of the 6970 CFX setup, but the question is really about performance (given roughly equal clocks), micro stutter, difficulty over clocking, power, thermal dissipation requirements, etc.
So what do you think? Seems either setup can be had for about the same price. On the surface it looks like the 6990 would take less power and probably produce slightly less heat, but might not perform as well. Then again you have the option to add a 6970 to the 6990 later on for tri-fire.
Also, it seems that the OC on an unmatched pair of 6970s would be a little tougher, but maybe that's just my perception.
Thoughts?
Thoughts?
