I have OC'ed my CPU by 5% to 2.31 and my RAM is now at 231MHz. RAM timings are still the same. If I OC any higher, do I need to loosen my RAM timings or will this cause a bottleneck?
I'm a newbie overclocker so any help is appreciated.
