I do about 50% gaming and 50% encoding / video or picture editing. I dont want to spend the $$ on an i7 unless another $199 sale shows up. I plan to overclock lightly Id be happy with whatever I can get on stock voltage or perhaps a tiny above stock voltage. From what Ive read the 2500k should overclock slightly higher, but have slower performance per clock so they are basically a wash performance wise. Price wise they are about a wash depending on what is in stock at Microcenter. Ill need to buy a motherboard, so the 3570k would be slightly cheaper if/when they get more Asrocks in stock near me.
So everything appears nearly equal, except perhaps heat. And the 2500k seems to run cooler, hence should be quieter for an air HSF to cool. Is that the case for light overclocking? Say 4.2/4.4 ghz will Sandy run cooler? Or is Ivy cooler at light overclocking scenarios?
Note that I wont use the integrated graphics, and dont think Ill use Quick sync.
