I have been offered either of these processors for £125
P4 3.4 GHZ/512/800 SL793 MALAY
P4 3.4 GHZ1MB/800 SL7E6 COSTA RICA
My problem is determining which would give me the better performance with my current setup. I currently have:
-Abit MAX3 Motherboard
-OCZ PC3700 Gold Mem 512Mx2 (should be able to get to 250-255Mhz)
-OCZ Modstream PSU rated 580W
-Radeon 9700Pro AGP
-Antec server case with 2x 80mm fans in front & 2x 80mm fans in rear
-ThermalTake XP90 Cooler
I would like to get maximum performance out of the chosen CPU so that the system will last me at least 18-24months with capable speeds before considering a new dual core rig. One of my key uses for system is rendering invideo editing so more performance the better. Im not prepared to go to lenghths of water cooling & so present CPU cooler will have to do. Also i like to leave my system running pretty much 24/7 so stability & temperature needs to be taken into account
-I am aware that at core speeds the Northwood will do better but as im looking to overclock to at least a target of 3.8GHz will the Prescott do better ? How much better ?
- Can i get both CPU's to at least 3.8Mhz comfortably with my setup ?
- Will either allow me to go any higher with my cooling setup ?
- At what MHz will the cooling the Presscot become an issue ?
- Im also aware that SL7E6 can have its multiplier unlocked. Does that help in my case?
-Radeon 9700Pro AGP
