Heats sinks are moving heat?
The heat travels across the material so so well?
I'm curious since the heat source can push the heat only so far.
Heat causing activity pushing the heat along?
Cooling fan creating low heat zone pulling the heat along.
I did try wrapping the exposed thermal pipe of a laptop heatsink with
electrical tape with at least the casing being cooler and I think
my temps being 10c lower.
Insulation With Cool/Cooling Zones.
Heat pipe insulated,
-----___c___c_____c--------cooling points?
fan/l------------------------------lcpu
----l------------------------------l
creating low heat zones to pull energy
-----___c+++__c++___c+----c+--c+++ cold to colder
multi fan/fan channels/other
fan--------------------------------------
fan2-----c--------c-------c---------c--
multi line same overall or larger size?
each insulated?
No interaction
Differing Combination Combinations of Interactions
Shapes in the line to effectively push
the heat-----
heat pipe
ooooo\ooo\oo\ooo
oooooooooooooo heat
ooooo/ooo/oo/oo
bottle necks as heat passes through to force heat by activity
down the line creating a block making heat have an easier flow
route shape.material allowing peaks of heat transfer one way?
ooooo/ooo/oo/ooo
oooooooooooooo heat
ooooo\ooo\oo\oo
l----loooooooooooooool-fan cooling pipe
l----lo------------------------l
lfanl-ooooooooooooolheat
l----l----o--------------------l
l----l---o---------------------l
l----loooooooooooooo-l-fan, same /other
Combination of heat going from one line to another in different patterns
heat going in direction sets inverse, together, other to push and pull heat?
Instead of even heat flow? near cooling point separate isolated line
going to another cooling point, or at any other locations.
multiline- thermally insulating heat sink fan contact points from each other.
-CPU Covering being made of Copper instead of current material?
copper layer in cpu over cpu part of cpu cover.
CPU to-heat sink /fan being one solid object.
In desktops/other with cover no thermal paste between cpu cover and heatsink.
Making cpu cover part of heatsink in laptop desktop/other
Thermal transfer ability of silicon?
Cpu having copper/other lines into cpu copper/other coating? top/bottom/sides?
If silicon transfers heat better silicon heatsink?
Silicon line/other in heatsink?
Hollow heatsink?
air being vacuumed very fast through heatsink?
Cooling line and maybe pulling heat?
Surrounded by air chamber pulling air,
with insulation on the outside?
Physically bind heatsink to cpu/gpu?
Top plate/copper/other
Take to store/other weld/de-weld
heatsink to plate.
Silver line through middle copper heat sink?
Diamond seems to be able to transfer heat well.
Is the technique available yet to shape man made
diamonds into heat sinks,channels,lines,other?
Take lines of diamond material,
put in copper/other heatsink?
Airplane Wing design----
silver/other
what does this do to light/other?
Heat build up?
.........................---- b---------------
........---- b---------------------
loop or don't
b--------0 ------------ =b----
Or any direction
Copper other line? silver other at b point?
This is not making sense and people are complaining.
You need to stop with these kinds of technobabble threads.
esquared
Anandtech Forum Director
each insulated?
No interaction
the heat-----
heat pipe
ooooo\ooo\oo\ooo
oooooooooooooo heat
ooooo/ooo/oo/oo
ooooo/ooo/oo/ooo
oooooooooooooo heat
ooooo\ooo\oo\oo
Hollow heatsink?
heatsink to plate.
silver/other
Heat build up?
loop or don't
Or any direction
esquared
