Better Cables for Klipsch Promedia 4.1s
Anubis
78,712
427
tbqhwy.com
i have the 4.1s and the cables that came with them arent cuttin it anymore. i heard that people were runnin monster cables or other high end audio cables for them and i was woundering where i coule get some for myself. or if there is something else that i can do to improve audio quality please LMK
Mookow
10,162
Heh. Monster Cables = snake oil.
If you find any manufacturer that has done an ABX test and shown a difference, tell me.
Anubis
78,712
427
tbqhwy.com
sweet. thanks. i might try makin my own first. cause im good at that. and if that dosent work i know where to buy them
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
I made my own using radio shack wire, lemme see if i can find the archived thread...
aphex
Moderator
Jul 19, 2001
38,572
Well nevermind on that, its already been trashed from the archives too :)
0roo0roo
64,795
84
just get some 16 guage, probably 12 bux for 50 feet at radio shack or wherever. either solder onto a mini plug or use a solderless mini plug from radio shack, uses little screws:p i used a crimp on loop thing on one end:p
Colt45
19,720
it isnt going to make any difference.
that said, its your money, and if you spend it anyways, you're a fvcktard. :p
0roo0roo
64,795
84
theres the bonus of length, being able to hide ur wires better for the rears:) i think up to 25 feet is fine.. that should be enuph for normal situations:p
aphex
Moderator
Jul 19, 2001
38,572
tact is a virtue :)
