GTaudiophile
Is there an XP Tweak Guide out there for those who just installed the OS? In other words, is it easier to uninstall the "bloatware" before you start installing drivers, apps, etc, and is there a Guide that takes you through the steps of uninstalling that bloat and making XP more efficient right after the OS is installed?
My plan for installing XP:
Install XP on a brand-new, NTFS-formatted harddrive.
Install drivers.
Run Windows Update.
Use a Tweaking Guide to remove bloat.
Install other apps.
Also, is it best to install new hardware/drivers one-by-one after installing the OS, or should I install all the hardware, install the OS, and let XP handle it all?
Install drivers.
Run Windows Update.
Install other apps.
