Best wood for stairs
TechBoyJK
16,699
60
Hi All,
Simple question. We need to replace the steps on our basement stairs. The stringers are fine, but since we're going to wall in the stairs we need the steps to be flush with the stringers, and they overhang an inch on each side.
Rather than pull off and cut the existing stairs, we'd like to cut new ones. The existing ones are very old, warped and just all around nasty looking.
I'm wanting a nice, firm, strong wood that will stand up to humidity (basement) and can be stained to look nice.
TBJK
Humpy
4,464
596
Bocote without a doubt.
Strong as heck and looks good stained.
It's the best!
boomerang
18,883
641
I saw what you want on the latest episode of Ask This Old House but can't find the information on who makes or stocks them. Edge glued stair treads wrapped in a veneer. They come with a bull nose on the front. You'd cut them to length and width.
Where to buy them is the question. A reference is made to "the home center".
https://www.youtube.com/watch?v=Pdg4xRb9qzg
I guess one question would be is if the veneer is something you'd be happy with when stained. The video talks of painting which leads me to believe the veneer is probably either a birch or pine. Birch can stain up pretty nice but pine can be blotchy especially if you go with a light color.
Maybe these people would be worth getting in contact with.
http://www.stair-treads.com/faq/edge-glued-stair-treads.html
Humpy
4,464
596
Doesn't strike me as something one would use for steps. Makes a nice looking guitar, though.
Pricing/Availability: Likely to be somewhat expensive, close to other mid-to-high priced exotic hardwoods.
Common Uses: Fine furniture, cabinetry, flooring, veneer, boatbuilding, musical instruments, gunstocks, turned objects, and other small specialty wood items.
http://www.wood-database.com/bocote/
Steps = flooring!
Maybe I was being a bit facetious though.
Nearly every home center/lumber yard has dozens of options for stair treads. Raw, pre-finished, domestic, exotic, hard, soft, they have it. Just pick one.
UnklSnappy
626
Carson Dyle
8,173
524
If he's going to enclose the stairwell completely, it should be obvious that aesthetics aren't the most important issue. Make it solid, make it look nice, don't break the bank.
Speaking of which, I'm not at all a fan of the idea of fully enclosing the basement stairwell. My biggest reservation and what I dislike most about finished basements is that shitty, narrow stairwell, usually accessed through a door in a back hallway or kitchen. Fully enclosing it just makes it worse. Upgrading the treads and the railings makes perfect sense, though.
TechBoyJK
16,699
60
We're actually only enclosing the left side of the stairwell. The right side will remain open. The left side of the stair well is where my music room is and we need to contain it.
Humpy
4,464
596
The OP, and some of the replies, are a bit confusing with giving an impression that the current treads are not going to be removed.
Unless you want to create death stairs (assuming they aren't already) the thickness of the treads cannot change. Meaning you'll have to remove the current ones and replace them with something of the same thickness. If you just slap new treads on top of what's there, which a lot of people do, the first and last steps will have a different rise.
The code I'm familiar with allows a 1/4" variance in rise, and even that's noticeable.
gbeirn
451
13
Painted or carpets: pine
Stained: oak
If you are only replacing the treads and maybe risers I still don't know how well it will look with the old stringers.
Source: in my teenage years used to work in a stair place.
Jul 9, 2009
10,757
2,086
Usually oak due to toughness and looks. You can sometimes find Poplar, fir or pine cheaper. I'd stay away from any veneers.
Phaeton
If you're going to carpet or paint them, I'd go with pine. You can get them with one square and one finished edge, or both ends square and round one edge yourself.
If you're going to stain them, go with oak. If you do go with oak, get them with one mitered edge for the open side.
You should be able to get oak for right around the same price as pine or poplar, so it's down to what look you want. My personal choice is always oak. Then again, I am a wood floor guy.
TechBoyJK
16,699
60
Decided since we're ultimately going to carpet, that I'm just going to go with pine. Going to cut them myself and round the edge. Precut ones at lowes and homedepot are both too wide and deep and will end up requiring just as much work to get fitted.
Reactions: Phaeton
paperfist
6,539
286
www.the-teh.com
No offense, but pine is going to look terrible in a few months of traffic. It's too soft.
Oak is $$$ but king. It's like installing a real hardwood floor, you can sand the stuff a lifetime if ever needed and refinish.
Mandres
944
58
I wouldn't use pine either, unless you have access to old-growth stuff. Poplar is a lot cheaper than oak and will hold up better than soft pine.
