hans030390
Question up top. What settings would you recommend to get the best range, signal strength/quality, and stability?
Originally posted by: JackMDS
Best?
There is No best, the setting is for functional configuration, and you set it according to what you want to do with it?
if you want to use it as a regular Wireless just change the Device Name the SSID name, and choose the best channel.
Originally posted by: n0cmonkey
I don't have the exact same model buffalo, but most of the defaults are working fine for me.
You haven't defined the term better. Better how? You can boost the signal strength, but be careful you don't burn the thing up. You can client mode (the reason I bought the thing and flashed it). It all depends on your definition or better. 😉
