Best Wireless Router
NJLOAD
I own the Linksys WRG54G model and keep getting knocked off the Internet, I have updated the firmware to current and when I experience the problem the only resolve is to unplug it from the power supply and then replug and then go to my network connection on the computer and do a repair. I have a laptop with a Linksys wireless adapter so I need something that is compatible with that also.
Any help is appreciated.
NJLOAD
are you doing a lot of bittorent transfers? Many wifi routers lockup b/c bittorrent clients can open 100's or 1000's of connections, and show symptoms like you describe. If so, reduce the # of connections per torrent and globally in your client and you may have some success.
