Best wireless router w/ USB printserver?
halfadder
I am helping someone upgrade their computer setup. They have a cable modem connected to their PC via a basic 1+1 port firewall router. In the next few days they will be buying a laptop with 802.11g support and would like to replace the router with a wireless router. It would be great if the same router could also become a USB printer server for both the wireless laptop and the hardwired PC. What do you recommend?
It is Not an issue of best since there are very few devices that have such a combo.
If the Wireless is used for general surfing and at close proximity just get the cheapest of the combos
Otherwise, depending on the needs get a suitable Cable/DSL Router and a stand-alone printer server, or better off a Network capable printer.
Link to: Wireless What Should I Get?
:sun:
