Netgear WNDR3700... I have that and its awesome! Set encryption to WPA2 and connection speeds to 300Mbps on both the 2.4GHz and 5GHz to maximize WiFi N speeds, signal strength, and connection... you will never reach 300Mbps because its only theoretical... only negative thing is you cannot manually set the channel widths to 40Mhz (doubles throughput speeds and is what you need to maximize WiFi N usage) on the 2.4GHz because its on auto... 5GHz is only 40Mhz. I use SAMBA and UPNP Shares for streaming video to media players and PCs and it works great! Retail price is $149.99
