best wireless mouse
dshodson
484
what is the best wireless mouse out there
i have an older non optical logitech one but its starting to fade and need a new one
would be best if it worked with my existing keyboard but that isnt a requirement
D
Mday
18,647
Originally posted by: computer89
Simple the MX700 if you need wireless, MX500 if not.
the mx500 is not wireless. the mx700 is by far the most popular.
i recommend getting whatever fits your hand the best.
Robet
144
With the MX700 you would have to use the receiver that came with it in order to take advantage of the recharger. If you have a cordless keyboard as well, would the receivers interfere with each other?
madthumbs
Banned
Oct 1, 2000
2,680
I have the older reciever.... have them both hooked up (not compatable), they work great together.
Mem
21,476
13
Quote
Mday he didn`t say it was,from his quote above he was saying for wireless go MX700 ,for corded go MX500 ;).
