Best Wireless Keyboard w/Touchpad
wege12
My gaming PC is hooked up to my 55" OLED TV as I prefer gaming on a couch over a desk. However, it seems the options for high quality wireless keyboards with a built in touchpad are limited. I used to have the Microsoft keyboard (linked below) which worked fine but it doesn't have a backlight for the keys which makes using it difficult. I did end up ordering the Logitech K830 with backlight but I find the touchpad on it less accurate and sensitive than the Microsoft one.
So what do you guys use?
Microsoft keyboard: https://www.amazon.com/dp/B00IICMUWS/ref=psdc_12879431_t2_B07CM5NZRC
Logitech K830: https://www.amazon.com/dp/B00ZOPVSKW/ref=psdc_12879431_t3_B07CM5NZRC
Two solutions--learn touch typing to use the MS one in the dark. 😀
Or maybe get a separate touchpad and keyboard if you have a surface that you put them on.
