Cut a deck of cards. Rock, Paper, Scissor. However you want to choose via the luck of the draw. Point is, there is not a major difference in any of those you've listed. Check and see what features you like and bounce that against the pricepoint your looking at.
Originally posted by: mauiblue
I bought a D-Link wireless router (DI-624) and wireless PCI adapter (DWL-G520) earlier this month. I got it setup within a few minutes out of the box. I did call tech support for some minor issues but I have no problems or complaints with the products I have. Tech support is very helpful and knowledgeable. They even send you an email after you hang up with them stating the issue you called them about and the resolution.
Question 1: If and when I set up a wireless network, can I still use my ethernet connection between PC's for those big transfers (backups)?
Question 2: Will my Internet experience suffer from using the wireless network?
