Best Wireless Headphones..?
amdhunter
23,332
249
I keep running over the damned cords over and over, which eventually break the wires. I want to buy a pair of wireless phones, but I fear that they would have totally disgusting sound.
Anyone know a good pair (less than 80 bucks?) that they can recommend? I'd like something that just sounds crisp, with a nice low end.
I've never used wireless phones before, what can I realistically expect from them? FYI, I have a LOT of wireless devices in my home, from 900MHz - 5.4GHz, I have already thrown away a wireless dlink router due to interference problems... :(
RFtesla
99
Those HD 280 Pros have amazing sound, I've got a pair that have lasted me several years.
n7
21,281
4
I have the Senny RS-110s.
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=newHD-4
They aren't very high end, but they do have good sound & great range.
Only slightly annoying thing is that if you're doing something on the PC that makes absolutely no noise for a while, they tend to tune into phone calls from all over my apartment :laugh:
Minor issue though, since i'm usually listening to music or doing something that makes sound on the PC.
So
25,923
17
QFT. I love mine. Quite durable.
yowolabi
4,183
This is the same problem I have. I've ruined so many pairs of headphones by yanking the wire too hard at some point.
Kaido
Feb 14, 2004
50,927
6,868
I have had my Sennheiser HD-570 (wired) headphones for a couple-few years and I run over the cord all the time...it's made of Kevlar ;)
amdhunter
23,332
249
Are those 5.1 headphones worth it? Will they work on an Audigy card for gaming purposes?
Although I use my box mainly for music listening, I would think it'd be kinda neat to have 5.1 since having speakers is not an option for me. (no room for anything)
