Best Wireless controllers for PS2 ??
Zombie
I would like to buy at least 2 wireless controllers but have no clue about quality of those controllers ??
What are some good ones ?? ergonomically as well as quality wise ??
thanks.
I have a couple Pelican ones that are ok but they feel a bit cheap, but I still prefer to use the wired version if I'm sitting close enough.
that's the thing my living room is kinda big and GF is making a fuss about me buying bean bags. Couch is kinda far from TV and I don't think extension cables will do it.
Yes I looked at Pelican and don't really care for the button layout.l
The problem I have with the pelicans is the shoulder buttons. Instead of the normal contorller layout, they made 2 of them more into triggers than buttons. So in games where you actually need to use all 4 shoulder buttons, its too awkward to hold so you can use all 4 quickly.
