Best Wireless Access Points?
I'm looking for recommendations for high quality "vanilla" Wireless Access Points. By that I mean WAPs that do not have built in routers but are used for WAP only. I have an Asus RT-N66U but it's overkill with all the built in router features and I'm hoping to find something equivalent that is correspondingly less expensive.
There are few pure Access Points at the Entry Level Class and they are Not less expensive than Wireless Routers.
Thus if you want really Good Access Point use the Asus. Hopefully you will Not have "Psychological Problems" from knowing that all of these Routing circuit are Not used.
I use few of these as Dual Band Access Point but the Wireless is Not as good as the Asus.
http://www.newegg.com/Product/Produc...82E16833162070
Using Wireless Cable/DSL Routers (or Modem/Wireless Router) as a Switch with an Access Point - http://www.ezlan.net/router_AP.html
I have an Engenius ECB300 AP. It gets out far even out to the boatdock. My home is 2300SQFt Concrete/Rocklathe construction . It gets out far and solid performance even with a bunch of wireless devices on the network (ie streaming cameras,Rokus,TV,etc..)
And its POE which is nice since I just have it plugged into my 5505 poe port, less cables.
I only need one unit.
They run 99 bucks.
