Best way to use Artic Coolings MX-2 for a quad?
AndyD2k
824
Artic Silver shows that a line be should be used for their line of thermal compounds. Artic Cooling recommends a drop of compound in the middle and then let the heatsink spread it.
I would rather avoid having to reapply so hoping someone can help me choose between these two methods.
manimal
13,559
8
I did the small line across the cores and then used the HSF to spread it, for years I did the finger condom and spread it myself and always got great temps, to each his own I guess.....
AndyD2k
824
I did a combo of line and middle - figured if my temps suck, then I can always reapply. installing the top part of the ultima 90 is actually easier than I thought it would be so if I have to reapply then oh well :) Thanks!
AndyD2k
824
The problem is that their instructions are for old cpus. The quads from what understand need different application. Well, that is if I go by what Arctic Silver is saying. I'll see how my temps are when I finally finish my build within the next week
error8
3,204
I always use the spreading of the arctic silver paste with the finger dressed in a plastic bag. I also put just a very small amount on the heatsink too. Their guide didn't work for me because I was getting incredible high temperatures with my brisbane X2. So my advice is don't follow their guide, and just try to have a very, very thin layer of paste spread evenly on the hole surface of the HSF, and an even thinner layer on the heatsink itself. And also remember to clean both surfaces with isopropylic alcohol first.
AndyD2k
824
Yeah, I cleaned both using Arctic Clean that I still had around from my last build. I'll see what my results are after I finish the build. I'm expecting temps below 40C idle due time of the year etc. If I'm getting above that, then I'll probably have to do a better job of spreading the thermal compound
AndyD2k
824
Alright, I'm bumping this up in hopes that others get to chime in. I'm thinking that I might be better off spreading the mx-2 on the entire cpu
