Best way to transfer large information to another computer over internet?
0roo0roo
64,795
84
Originally posted by: gwlam12
send it over aim. no need to setup ftp
if your lucky enough to be on dialup since basically 99% of broadband peeps are behind routers.
Shuten
Use KDX or Hotline. They essentially use FTP protocal but allow resume and the servers are
easy to set up and you can get by firewalls by going through http proxy.
www.haxialsoftware.com - for KDX client & server
- go to tucows.com for hotline client & server
Juniper
2,025
With one gig, your connection will sure get broken before you can complete your transfer. Try using get right software also :) It allows you to have simultaneous downloads of 4 parts, hence speed up ur download, and if your connection breaks, that you won't have to re-start all over. Cheers.
dabuddha
19,579
17
CD-R will be your best bet
nothing like a broken transfer resulting in corrupted files when you're ftping :(
silverpig
27,703
12
Originally posted by: BingBongWongFooey
scp
SCP is good. Similar to FTP IIRC.
Yeesh, I'm sounding like Tom Clancy what with all these acronyms.
Nope, nothing like it :p
Erm, SSH I meant. I used winSCP to transfer thing from my windows computer to my linux computer using that. IIRC, you connect using your SSH keys and the graphical interface is similart to an ftp. But yeah. :)
Jan 31, 2002
40,819
Reminds me of a mid-90's joke (remember how fast things were back then)
Customer: "What's the fastest way to transfer 500 megabytes of data between Texas and New York daily?"
Sales Rep: "FedEx."
- M4H
0roo0roo
64,795
84
whats the easiest program to use behind a router. accessable to people behind routers too??
aim and icq totally fail.
ftp, which ftp program is easiest to use?
