- Oct 4, 2002
- 2,188
- 99
- 91
I've read through some archived threads and other ones dealing with stress testing. I've seen some excellent discussions on the subject and hope to get some verteran OC input.
Question 1: How long (approximately) does memtest86 take to go through all of its tests?
Question 2: Should this be looped a few times to ensure stability? or is once enough?
Question 3: Is looping Prime95 the best way to stress test a 1600+ O/C'd? I'm not equipped to do any encoding. Are there any other applications that stress the CPU that I can use in conjunction with Prime95?
Question 4: What is considered "long enough"? 12 hours? 24 hours? Until the CPU temps level off?
Question 5: Is there a difference between the voltage listed in CPU-Z for the processor and the voltage listed in the BIOS?
If anyone has any other O/C'ing advice or links to old archived threads I missed in my search, that would be appreciated.
P-X
P-X
