Question Best way to test internet connection speed
merk
Hi All,
Windows 10 64bit
Moved recently and was lucky enough that they have fiber internet. However, I've never gotten anything near a 1gb on downloads or uploads. Spoke with their tech support and turns out i'm supposed to be getting 400mbps instead of 1gbps. But I havent even been getting 400mbps.
My PC is wired into the router, not using wifi.
I decided to do some testing and the results are very inconclusive. The testing speeds can vary widely not only by what website I'm using, but also what browser I'm using. For example, using the google fiber speedtest page, the speeds will be 2x faster, or more, then if i run the same test in IE.
using speedtest.net, i get really fast uploads in IE, but downloads are slow in both IE and Chrome...but in firefox i get fast downloads.
And just to see if it's a problem with my desktop, i ran the same test on my laptop. More or less the same results, except on my laptop in firefox, it gets fast uploads and downloads on speedtest.net
There doesnt seem to be a single test that behaves consistently. So - what would be the best way to test my connection speed?
The most accurate test I've found is dslreports.com/speedtest.
A quick and dirty test is fast.com but that may not help.
