Best way to temporarily dye hair bright green?
brigden
8,702
I have extremely thick dark brown hair. I'm going to need to dye it bright green on Halloween, but only for the one night. I need advice on what products to use and how to apply them. I've never done something like this.
I've been recommended Kool Aid or Jello.
Very old thread revived by noob.
admin allisolm
Drakkon
8,401
bleach it....dye it green....day after dye with equal ammounts black and red
of course at some point just have to shave it all off :D
nakedfrog
61,290
16,794
Yes, Kool-aid, Jello, or some of that hair spray. Manic Panic doesn't wash out overnight, so I wouldn't recommend it.
raptor13
You're either doing a thorough bleaching job first or it's not going to happen. Unless you want to shave your heard afterwards, the bleach won't be a one day thing, obviously.
I suggest a wig. Seriously.
Shawn
32,236
53
Get one that says "permanant" on it. Don't worry though, it'll wash out.
LordMaul
15,168
Definitely look for the spray. Did it for last Halloween...my hair is also dark brown, but was short and spiked (gel used beforehand, just sprayed it with the green stuff after it dried just like spray paint). I used a lot, but it was BRIGHT "neon" green.
Aug 25, 2004
11,151
go for the colored gel..... it's not easy to get a uniform color all over your head with the spray.
whatever option you go for, remember to buy some real good conditioner.... you need it... lots of it.
andylawcc
18,183
i sincerely recommend you go with a wig...
with the color of hair you have , it is almost destructive to make it bright green. beside, you will probably not get the brightness you want if going with hair dye.
trust me on this.
thirdlegstump
Banned
Feb 12, 2001
8,713
I used to have green/red/blueish hair but since I naturally have black hair, I had to bleach it first otherwise no color will stand out. Dying on top of dark hair will result in nothing heh.
badmouse
2,862
The kool-aid works if you have bleached or really light hair. Otherwise it gives you a kind of greenish highlight, if you can see any green at all. And then, beware of water (rain, apple bobbing, etc.) because it will drip all over the place.
Cheap & fun, though.
Use the spray stuff, practice first.
MichaelD
31,528
Food coloring. It washes right out. Really.
:evil:
I've not the nutz to do something like this anymore...someone might see me....I've gotten too responsible in my older years. :eek: I think it's Karma to make up for all the times I should have DIED b/t the ages of 16 and 25. :eek:
DingDingDao
3,044
ICE Spiker Colorz (halfway down the page). There's 3 different kinds, but each one has a variety of green. I've used the blue, and metallic copper before (I have black hair). Works really well, washes out easily. You should be able to find it at a salon or something.
