Best way to store/preserve candy bars?
Borkil
248
So I decided it would be cheaper to buy in bulk so I bought 48 3 musketeer bars. What's the best way to store them? I was thinking refrigerator but I've heard that actually isn't good.
ElFenix
102,402
8,574
in an air tight container in a dark closet that doesn't get above 70ish degrees.
Feb 6, 2007
16,432
Considering you're probably going to eat them all within a week, I'd say your fine leaving them wherever. Source: you bought 48 candy bars at once.
Puppies04
5,909
17
I keep mine in shops you can pop in and hand over money whenever you fancy one.
purbeast0
53,638
6,522
how long do you plan on keeping these 48 candy bars? i'd think they would be just fine sitting out anywhere cause realistically you will probably eat like 12 a day.
BurnItDwn
26,353
1,862
That is a lot of candy bars. I think they will all go bad in like a week or two, you should probably send them to your favorite anandtech forum members.
sixone
25,030
61
Put them in your freezer. When you want one, they'll be frozen hard.
Best diet ever. :D
DrunkenSano
3,892
490
Store them in your belly.
Oct 20, 2005
10,978
44
OP, how often do you eat candy bars?
If you are eating like 3-5 per week, then you'd probably be ok just leaving them out.
Nov 7, 2000
16,403
you can refrigerate or freeze them to inhibit bacterial growth
but before eating you should probably boil them just to make sure
3 musketeers contain no preservatives
