Best way to setup 2 120mm fans, and a 80mm fan in my Enlight 7237 case
chiwawa626
12,013
Whats the Best way to setup 2 120mm fans, and a 80mm fan in my Enlight 7237 case?
Which should i put for intake? or which for outake? I also have a 2coolpc cooler to bring air up to the cpu, that has a Alpha PAL6035 on it with the delta 38cfm fan. what should i do?
Howard
47,982
10
Do you already have the holes installed, or are you going to cut them depending on where we tell you?
chiwawa626
12,013
havent done anything yet, but i dont like the ideas of holes in my case, just want to put some fans INSIDE, without holes in the case
lenjack
2,706
7
These fans inside with no additional holes will be useless. Air blowing around in the case doesn't help...It needs to flow through holes from bottom to top.
Davegod75
5,320
i dont' think a 120mm fan will fit in the bottom front of this case. I was thinking about putting on there also but didn't think it would fit
Tuhran
8
I have this case, and was considering modifying it also. I would put one 120 in the front (I think it will fit), the 80 as a back exhaust, and the other 120 as a top blowhole.
Reconcile yourself to the task of putting holes in your case, and look around some of the hardware/cooling/overclocking sites to read up on how to do it right (all components out of the case before drilling; esp. the motherboard!)
Good Luck!
