best way to set up a 3.1 system?
makken
1,476
Hi guys,
I'm setting up a new TV in my room, and trying to figure out how to best work out the audio system. I have 3 bookshelf speakers and a subwolfer that I'll like to use as a 3.1 (L, R, center) system.
I'm wondering how to best hook up the speakers. I would like to use the TV as the switcher, so a 5.1 receiver seems like overkill.
The TV has an optical audio out. the subwolfer only accepts input in RCA L/R. How should I bridge this?
Thanks.
Hail The Brain Slug
3,784
3,101
In order to do anything with the optical audio output on your TV you will need a decoder. Either get a receiver that accepts optical audio (Pretty much any new receiver, if you're going on craigslist just check the older ones to be sure) or buy a standalone decoder from amazon for about $50-100 (search optical audio decoder).
If your bookshelf speakers are not active (self-amplified), it will probably be much simpler to just get a receiver to do your decoding and power the speakers. Make sure it has a subwoofer/LFE RCA output for your sub.
Usually TV's aren't great as input switchers/selectors. The menu interface can be clunky and slow. In my opinion, receivers are much better at the job and have a better selection of inputs.
makken
1,476
the speakers are not active.
Hmm, at that price for an audio decoder, it does sound like a receiver would be a better choice.
BurnItDwn
26,322
1,836
Go for cheap 5.1 reciever, you can run in 3.1 mode, or, maybe it would make sense to just run 2.1 and get cheap stereo reciveer, or a little T-amp ....
